Is there a reason why every time I see someone under 50 in a convertible, they're always pumping the music much louder than any other hardtop driver would?
And it's always chick music? Regardless of the gender of the driver...
yes, you spend your days cruising the gay strips
Point taken. But that's what insurance is for
But personally, I'd never buy a convertible..
My mate's Mx5 was broken into with a knife the other day...
I tried to convince him to leave it in the same spot with the rip in the roof and glue a bunch of razorblades behind the rip but he wasn't down for it :/
I'm under 50, I had a convertible two weeks ago.
I was pumping tupac and bonethugs in the bumbiest clothes I could find. AND drove through Hampton park.
People got angry. Hopefully people thought it was stolen lol
1:11 ftw
Edited by kaitoukid
Yep but mine are different colour, f**k running white wheels
mine
Haha yeah I have even seen them near my house on a Rangey
mine
I think these rims were an option in GTA: San Andreas at the Low Rider mod garages... You were only allowed to get them if you already had knuckle dusters and your top teeth removed for a mad set of gold fronts.
Nostalgia = Spending $40,000 on your car modding it up to be awesome, nitrous etc... nek minit you drive it, realise it's still a boat, it flips and catches on fire....
twilight_table_flip_outline_by_dori_to-d
I only just noticed the rust on the rolled guard of that red GTI. I guess lot of people are canaries in a gold mine with what the future holds for rolled guards (affecting resale, damaged paint etc.)
Targa Tasmania? LOL :P
Haha yeah offset is really low for the mk5, would have rubbed/burnt paint with zero f**ks given
If it's done right you won't have any issues with rust etc later on, most US guys don't care
Mine burnt on drivers side when I put land rover wheels on, but I then rubbed it back properly and then put proper touch up paint and have no issues at all
Brown
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
