2 hours left at work... Then leaving tonight for... http://stupiddope.com/2011/06/23/koro-sun-resort-vanua-levu-island-fiji/koro-sun-resort-fiji/
2 hours never felt so long (even though we're leaving half an hour early to go to a local microbrewery for some drinky drinks)
Why would u want monthly. I'm on monthly now and it's a pain in the fkn ass hole
+1 for monthly club. Considering leaving cause its shit.
Drift Ghost HD - $450
extra battery - $29
Rollbar mount - $39
SDHC card 32gb - $50
hmmm starts to add up doesnt it.
Monthly because he has to blow his first pay cheque, therefore more money blown on blackjack and hookers than a fortnightly or weekly salary.
/strongawareofallforumjokes
my rent is due 4 days before payday, so have to budget whole month. bills are usually here and there.
so mine was meant to be 2 days b4 pay.
so when I moved in talked to land son of rajab, and first rent payed 1 month and a week.
and then it now due 5 days after pay every month,
Understanding folk at my estate agent.
I think he means the lid fellas and I hate this also, for 2 reasons,
1..I dont like smelling a stinking toilet bowl everytime I walk past it
2..the dog drinks from it, then the missus yells at the poor dog..well if you put the f**king lid down you slackass.... :rant:
close the lid or close the door..i will settle for either
I close the door and leave the cover open. Otherwise the cat pulls all the toilet paper off the roll.
