I'm only running fmic and exhaust, boost sitting on 9psi after those mods.
Thought I'll be alright with 1.1mm since not running much power, shall re-gap to 0.8mm and perhaps coilpacks.
Misfiring better go away before deca!
If you don't have new coilpacks forget about 1.1mm
Yeh mate, 6 burner + Teriyaki hotplate + wok burner, with a side sink/chopping board. Runs twin gas bottles. lol.
two of the big ones..
i would be glad to come around with wagyu, but need to tend to jess.. as the drugs wear off she is in more pain lol
just use bscp6es or bcpr7es and gap to 0.8 at all times...
this has been the most proven plug / gap combo on SAU for like 10 years for almost every conceivable application.
I do not even come close to understanding why people insist on running 1.1 and then spend days arguing their point on the forums when it has been proven to be less effective, time after time after time.
we have this wealth of knowledge (including an 11ty billion page spark plug thread) for a reason
im planning on buying a Ghost HD next week and just thinking about using a GPS Laptimer and then overlaying the info to the video... Reading through a bunch of product pages (http://www.gps-laptimer.de/Features.html, racechrono) and none say if the footage has to be recorded with the phone or if it can be merged with a mpeg or something.
How does everyone else do it?
Track vision is a $150 program for PC that will let you merge the info... but you still have to record the data and film it as well :|
Yeah double check Anthony, you still have the standard boost solenoid don't you? Definitely unusual to spike 4psi with that.
Yeah definitely hitting 1.5 bar on full boost according to defi gauge
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
