I think more driver training or education is the solution or at least part of it.
Banning cars or turbos won't do anything for road toll, I mean it hasn't done shit already right? There's not a massive number of high powered cars crashing it's all kinds. The type of person to get high powered car would of crashed a low powered car as well imo. Hell I had a n/a skyline with no power and stacked that into a tree when I was young and stupid / inexperienced.
Anyone can do 160km/h in a Hyandai and lose control come off the road hit a tree instant death.
  • Like 1
some good points there.
however one that has been dramatically over looked. your test.
make it harder. and i mean f**k loads harder. the quality of Australian drivers as a rule is shocking compared to other developed country's i have driven in.
tailgating. not being able to stick to a speed. sitting in the overtaking lane for 40 mins. unrestricted trucks. zero courtesy, arrogance (ie look at this dickhead, he's not getting past me) all major flaws that stick out alot here. and compared to other countrys we have a lot less drivers.
That's exactly what I mean by education / training it all needs to be harder than a 5min drive around the block.
Pretty sure Germany had like wet road / emergency stopping / sliding etc etc?
Edited by UNR33L
Also they need to adjust the bike rules too - a 19 year old can ride any bike he wants.
you are thinking of finland.
they require mandatory training for driving on ice and snow, as well as training on a skidpan where the instructor will purposely get the car out of the drivers control.
they made the test harder in 2008-9 to try and weed out the time wasters (ie. inexperienced and a large number of foreigners).
Victoads way of making it harder is instant fail in the first 5mins. First time I went for my licence the rear wheel touched the edge of the roundabout in a small street. pulled over, instant fail because it was in the first 5mins of the test. I was infuriated because if I'd made the mistake later in the test I would have only lost 5 points. apparently it's a way of "saving the testers time". kents
hahaha I know, but bikes are different bikes are stupidly quick dangerous if in the wrong hands.. you can buy a 9sec bike for like 10k if you've only done like 500km of road riding then jump on that - laters lol
I know someone that did everything correctly, then when he pulled up at the vic roads, the tester got out of the car and said
"that was 100% perfect, come back another time when you aren't on drugs"
fkn ROFL
FedEx says my Ghost HD cam should arrive at 5pm tonight............. but its tracking status hasnt passed the "information received" stage. hmmmm
Order rollbar mount express delivery from Sydney so fingers crossed all geared up for Sandown. and then DECA wew.
The road toll is basically nothing as is though, since the 70s the road toll has come down to almost 1/4 what it was and yet there are more than twice as many vehicles on the road people on the roads, cars are safer. Why do the government have this fixation on lowering the road toll? Is it because they can enact some quick fixit scheme that makes it look like they're tackling the big issues?
+1
And as long as people commit suicide, there will be a road toll.
As long as people die within 12 months of having been in a reported accident regardless of it being as a result of that incident or not there will always be a road toll.
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
