Yes it's terrible. That's why it's a sizeable restaurant with sometimes a 30 minute queue just to wait longer inside for a table, meanwhile the rest of the restaurants in Glen Waverley have empty tables...
/idiotlinesaustralia
downloaded and watched this before
http://www.imdb.com/title/tt1588173/
surprisingly not bad, at points you're like why the f**k am i watching this but can't stop watching lol - better than hangover 3 was
Edited by UNR33L
New levers are on, but new clutch cable didn't help :-/ clutch still not disengaging
So it won't let you change into gears? Or it won't let you move once in gear?
If the former and you've adjusted clutch properly, you got a worn pressure plate I'd say.
Won't change into gear.
Well shit
