What's been cracking wasteland? Went to deca and had a blast in the wet, never knew how much fun it was spinning all 4 wheels through 1st and 2nd was so much fun.... now to chase power to do it in the dry.
I've heard the loophole that I can say mines a replica of a 1988 model and can get club rego for my 1993 model!
orly?
stripped my RB26.
head looks like its in top shape.
piston #3 is f**ked just above the ring
bores look okay though? wtf?
orly?
stripped my RB26.
The Victorian club permit scheme allows members of car clubs (including motorcycle, trailer/caravan and machinery clubs) that are recognised by VicRoads to make limited use of historic vehicles on the road network.
A club permit can be issued to the following vehicles in the following categories:
  • Veteran vehicles – manufactured before 1 January 1919;
  • Vintage vehicles – manufactured after 31 December 1918 and before 1 January 1931
  • Classic and Historic vehicles - manufactured after 31 December 1930, but more than 25 years before the date of the application for a club permit.
These categories can include trailers and modified vehicles such as street rods. Vehicles which are replicas of vehicles in the above-mentioned categories may also be issued with a club permit.
keep the 20 in there until you can afford the 25/6 box
you will only destroy 20 and have to replace it.
better to be able to sell the RB20 & box as a package or to sell an unbroken box on it's own complete as opposed to small metal fragments
    • New CAS just turned up from NZ Wiring. Looks like a nice bit of gear.  So, yeah. Triggered, bro. Realised I may as well do the cam belt while mucking about with it so will order one of them.
