I got told a story just yesterday from a friend wife tried taking the car in for suddenly losing power. Caused by the dsg. They refused warranty saying the car had modified. All that the car had added from new was a baby seat. They took it to everyone they could without going to vcat.. Apparently got fixed but now they're chasing the bill. $8k for a replacement
+1 to there being more to this story.
There's always two sides. But I've seen the car and its definitely not modded, and they've had it since new so..
Reading the news article it seems like vw are doing any/everything to cover their asses. Which kind of make me believe my mate even more
But this is the news, which is almost always tainted
Parents Tiguan had oil leak, b4 even checking what was wrong they dropped a new DSG in it.
then found out it was a leaking head gasket.
SO seems that yeah they having much trouble with them so assume everything is caused by it.
guy in my team at work has a 180sx type x that's painted pearalescent purple with work meister TE35's, big turbo, huge intercooler and a forged SRDET20
it got dyno'd and made 285kw
BRO!
why anybody in this country would spend money on a golf when you can get a commodore for 1/4 of the price that will outperform it everywhere and rip skids is beyond me...
there is only one explanation,, top bloke hipsters....
BRO!
I think he lives near me. Hangs around with another one in silver with purple wheels.
They both drive like f**k heads
Lol
BRO!
Fully built and makes mild bolt ons rb25 power? MONEY WELL SPENT!
    • Dear folks My family members have 4 different cars : Triton 2015 and Corolla 2011 and Mazda3 2012 and Hyundai Elantra 2014 Looking to buy engine oil funnel spill free What I found are are below  https://www.amazon.com/gp/aw/d/B0BBTTJNKX?ref=ppx_pt2_mob_b_prod_image&th=1 https://www.ebay.com.au/itm/145553221359?srsltid=AfmBOoqYBU6Ptw0LU_bAp_k67U3qkF97HHvePkA7iHZw8vUmiwoIRaRr https://www.amazon.com/gp/product/B09X23TCS5?th=1 Is there a funnel with attachment that fits most cars ? Don't mind to spend for a decent quality  Thx
    • Stock ECU (or more accurately stock tune) absolutely refuses to go over 10psi and behaves like you have seen. The Nistune is the same if it is the stock tune. If the Nistune chip has been tuned, the resulting tune could be literally anything for any combination of parts. The Nistune just makes the stock ECU Tunable.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
