Car impounded from parking spot in st Kilda. ran into the tow truck and politely asked if he could grab my wallet "you are not allowed to touch the vehicle".
*sigh*
$50 says they'll be a ticket inspector on the train who will still issue me a ticket.
i suggest we assemble a team. a team of the very best. then we can avoid all the cameras with our excellent driving skills, grab your car, and make our escape.
i suggest also that we find an abandoned warehouse to construct our test track, and use many different types of cars and drivers to ascertain the best combination.
let the heist begin.
  • Like 1
*sigh*
Guy tried to tow the 33 once, 5 minutes before it became a clearway... Long story short he didn't have the balls to go through with it after I caught him. Don't think I have lost it that hard more than maybe 2 or 3 times in my life without actually getting in a fight.
Ended up with me repetedly demanding he hooks the car up and him refusing and apologising hahaha
Geez. thats harsh. I was very calm because I knew what kind of calibre people he would deal with. the yard had like 3 people complaining about abuse and "policies" and shit. I just wanted to save time and was in-out in a flash.
$345 for collecting car, Jonno reminded me about the parking fine on my windscreen :| another $141. Lesson learnt.
Yeah, put a big hole in my wallet. Dat uni budget. Now I always check the signs for where I park. haha
Took princess hwy home. wednesday at 10pm and there are already heros in falcadores just blasting it off at every light? Shieeeeeeeeeet
Wish I had a commo.
Was it a national tow truck? probably... nothing is too harsh for those scumbags.
the vultures sit there in clearways and hook cars up a few minutes before they are allowed to and drive off the absolute second the clock ticks over.
It's illegal but challenging it is not easy.
also, no way in hell anyone is taking my car while i'm standing there unless they are actual cops.
I am aware of their tricks so I NEVER park in clearways, and the one time I nearly had the car taken (mentioned earlier) I KNEW it was a clearway at 4:30, returned to my car at 4:25 and he was already on the ground trying to work out where to put the chain... hence my fury
I'd love to see them lay one hand on the car before that clock ticks over... Would be filming it and taking them to court after taking it to ACA and requesting others to come forward for a class action suit
But then the story would turn into Hoon driver assaults innocent tow truck driver.
Insert montage of cars doing donuts against tow trucks innocent family with newborn baby
  • Like 1
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
