So went to see fast 6 tonight..
usual FnF movie..
however we were in Director suite so we had grog..
and what turned out to be a joke at the start turned very ugly..
spoiler alert
take a drink every time family is mentioned....we ran out of alchyhol....
i was thinking just silver :P
though im leaning more towards meisters due to I dont have funds for tyres also right now lol so was going to go 18's - with GTC's id probably try 19's
i dunno with the purple car gold / silver would be alright
or I could be boring and go bronze te37's
didnt think it would be as hard as it is to settle on a set of wheels!
Ill buy the panas or swap you my meisters for them? Lol
thats the general answer with anything hospitality related. Unless you love to travel and work abroad.
I like to work abroad....... or 2
/cheeze
srsly tho...
I get paid the same to work 38 hours in my nice comfy office as running a busy-ass kitchen
usual FnF movie..
spoiler alert
Also saw it last night, they do mention it a lot don't they
/cheeze
srsly tho...
Argh was gonna make this joke prior to seeing your post; now it would just make me look like a biter.
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
