I've got a hankering for fried chicken, but want it to be healthy at the same time...
If only :/
Hmmmm... might settle for grilled chicken strips on the george foreman tonight... in wraps with sweet chilli mayo
why cannot more places work this well.
because straya flamin mongrel.
i ordered a single gauge from a place in SA, it took two weeks to get to me and it was a drop ship direct from the manufacturer in sydney.
in that time frame i could have got one from the states for the same price.
If only :/
fry it in water... win/lose
If only :/
Wraps are the bomb.
You can add so much to chicken wraps... ham wraps too. Hell even melted cheese in a wrap is grate.
If only :/
KFC!
same size man 18x10.5 +16
tempted to try 18x11s but i would need to buy a new set of tyres for them too since im running a bit of stretch on the 10.5's already
Just keep them, they are tough wheels!
aha they have some small buckles which was noticed while on dyno, can feel it through the wheel at over 100K also :(
so looking to buy a nice new set of something and get the panasports fixed up as soon as they come off
Edited by bluejeans
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
