I've got a hankering for fried chicken, but want it to be healthy at the same time...
If only :/
Hmmmm... might settle for grilled chicken strips on the george foreman tonight... in wraps with sweet chilli mayo
why cannot more places work this well.
because straya flamin mongrel.
i ordered a single gauge from a place in SA, it took two weeks to get to me and it was a drop ship direct from the manufacturer in sydney.
in that time frame i could have got one from the states for the same price.
If only :/
fry it in water... win/lose
If only :/
Wraps are the bomb.
You can add so much to chicken wraps... ham wraps too. Hell even melted cheese in a wrap is grate.
If only :/
KFC!
same size man 18x10.5 +16
tempted to try 18x11s but i would need to buy a new set of tyres for them too since im running a bit of stretch on the 10.5's already
Just keep them, they are tough wheels!
aha they have some small buckles which was noticed while on dyno, can feel it through the wheel at over 100K also :(
so looking to buy a nice new set of something and get the panasports fixed up as soon as they come off
Edited by bluejeans
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
    • Yeah, saw the ratios, not impressed. Would like the punch I have in the first gears now. With those ratios it won't be the same.  Also want the h pattern gearing, or at least a quiet gear set that don't need to come apart for service each year. Looks like the only "reasonable" way Is a 8hp70 transmission, but where is the fun in that🤷‍♂️
