Tread pattern is the same.
It's a different compound. Increased grip at temperature.
They might have had a play around with the sidewall as well, not sure.
But they are still selling both AD08 and AD08R. The R is only available in certain sizes at the moment.
$420 / tyre!!! No way.
OTR if you want AD08's or RTR if you want RS3. Both are under $400 / tyre.
iirc the AD08 is around $385 and the RS3 around $370.
You should, might, kinda be able to get AD08R's in 265 from OTR as well.
Hokie dokie! I'll keep that in mind
Tirerack would be good if the dollar was better
listed at $263USD a tyre on tirerack. But once you add shipping, GST, duties and convert back to AUD it gets exy
Oh, I see.
Edit: what's the tread wear rating on these two?
Well there is a story there....
AD08's are 180.
RS3's are 140 & 200. However there is no difference between the two. They simply had the tyres re-certified at a higher utqg for a racing series they were competing in. The 285/35 R18 RS3's I've used were 200 utqg.
Noticed any difference in wear between these two?
I know you run both in different size so that'd be in-direct comparison but I'm curious and I'm sure others will be too.
How many trackdays did you do with a set of ad08s before moving on with rs3's?
I only ran RS3 as I couldn't get AD08 in 285 or 295. I've done 15 track days on AD08's previously. Those tyres have gone on to be used another 5-6 times.
Ombudsment has taken on my case on the basis that my termination fee is more than my remaining balance.
Telco will be in touch to discuss
told ya... tell them you want to keep the handset and terminate the contract. Moving for work was unavoidable and you purchased the product in good faith assuming that there would be coverage in all major areas etc.
if you sound like you wont accept anything less, however don't come across as arrogant they will likely just give it to you as a commercial decision
f**ked it up. Rookie mistake.
Agreed to pay out the outstanding months ($290) vs the original termination fee of $440
Should have argued to get it less as there is no difference in keeping or cancelling the contract.
Ah well, next case ill be aware.
dw, fifo ymcmb
you can afford it
bahahaha
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
