Hmmmm DECA.... Considering Shockworks Coilovers and Whiteline Bushes before then... Wonder if its possible within a month, working full time?
Have already done the 4 Rear K-Frame and the 4 Diff Bushes with Whiteline goodness... So just Arms and a few other bits and pieces to go?
coilovers arent too hard to fit, but still needs alignment.
doing bushes DIY... yeah have fun with that :P
How do the shockworks coilovers compare the the BC ones?
Richo runs BC coilovers, seems to be good enough for him at the track
Coilovers I've got no troubles fitting...
Bushes, I'm not going to try ghetto remove any bushes that should to be pressed, ever again ;) Mike (Miguelone) and I spent a full afternoon trying to get the suckers out of my K Frame...
https://www.facebook.com/photo.php?v=10151330100116148&set=vb.641676147&type=3&theater
I've heard some very good things about them, local support is nice, they're only a few hundred more than BC BR's.
Currently I'm running Bilstein Shocks and Springs, I'm about 3cm too low at the zorst, I'd like something damper and height adjustable which is still silky smooth for the street (which my current setup isn't). Car was imported in 2006 with the Bilsteins on it, so they're getting pretty old I'd say.
Fair enough!
So now that your car is sorted when you coming back to the track?
yeah coilovers would be a pretty good upgrade. picking the right ones for daily use is the tricky part I reckon.
sif coilovers.
i got brand new bilstens and am getting eibach progressive rate springs.
silky smooth for daily duties and not too rolly for corners.
    • I feel like I'm missing something. You had an authorised installer come out and install a new alarm. Post install the car doesn't start, and you aren't getting the installer back to fix what they did wrong?
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
