Gladly, it's warmer here.
How've you been Simon? Feeling old yet? Hang overs lasting for days now as opposed to hours?
16c atm, max 18... but sunny and clear skies :)
Yeha, I'm feeling old :P
Also, no hangover... not drinking this month (apart from tonight, going out to dinner with some friends)
Not? Drinking? What is this concept? How does this work?
Whatever happened to the cool Simon?
These ratings on our profiles, how is that calculated? Why am I at excellent and grant at bad? Is that a warn bar or something?
There was like/unlike button (or reputation thing, can't remember, remembered ns.com had similar thing) on this forum back then which everyone unliked posts of my ranting on a car I had for 3 months back then (late 2010/2011), it went as far as -90 or something, yep I was shit flamin mongrel back then lol.
Not sure how did it reduce over time :/
I'm at 71 and have no idea how I got that high! Mines bigger than everyone else's. maybe it's a black person thing. ;)
hooray for camshaft shopping.
of course nothing can be bough from the same supplier... nobody likes Tomei springs, JUN charge a fortune for springs and retainers but their camshafts are $200 cheaper than average :confused:, JWT don't make springs or retainers, nobody likes BC camshafts....
Titman, yeah I saw the ending coming to some degree, it all felt a bit up in the air, but I was entertained!
Also I'll maybe be in for dat bbh tomorrow depending on time etc. Let me know brahs.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
