surely if you have to borrow 95% you are looking in the wrong area or need to scale back your expectations.
95% isn't as rare as you'd think a lot of people can service the mortgage comfortably but for whatever reason can't get the deposit together
20% deposits are rare particularly for first home buyers it's the best part of $100k in most instances so it's serious coin to have laying around
Also investors can and do borrow 95% regularly
well there is this, however we are talking a refinance, and in that case you may have initially borrowed with a good LVR however the property has lost value. eg, some douchelord government has built a freeway next to your house, the neighbours have all decided to live like cops and bring the whole street down, you live in rural QLD or even worse, you bought in a minimg area and mining ceased etc etc
there's ya 100+ LVR right there.
I have a guy on 240 in my portfolio
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
