It's up to the discretion of the officer. I didn't get a fine when I got defected they just said go clear it.
Yeah I know, I've been defected a few times and always get let go of the fine
But if you do get fined, just curious how much it is. Because $500 is alot of mulla
It was a Daytime meet at Carribean Gardens, Police were informed of the event beforehand so they were aware and ok'd it and promised no "move along" orders.
The meet was organised by the group HWY and it was a JDM / Euro Show n Shine Meet... in Knox... after informing pettets station of the location of a bunch of modified jdm cars. *sigh*
A girl on my FB has a sil80 (I think) and got done for $500 fine + RWC Required for Too Low and a Cracked Windscreen... I thought you needed 3 things for a rwc?
Though you lose your licence, a drink driving offence of between 0.05 & 0.07 is a $367 :/
And going through a red light is $361
Good to see the government see a loud exhaust as more dangerous
Nah if its a structural component(suspension) they can issue a major. And whatever fine they see fit..
And it also goes back to the thread about the dumbass doing 180kph with a full car in the wet.
All these people know full well that their cars are not road worthy, yet they choose to congregate in a large group, IN KNOX, and then cry when they get done.
Genius'
There's a reason I stay away from these sorts of meets nowdays ;) I'm too old for that kinda stress...
I still drive my car 300-350km in peak hour every week and I'm never hassled (haven't been pulled over properly in years) because I don't drive like an idiot and draw attention to myself... Hell just the other week I cruised straight through a Defect / Sheriff station that was set up on Boronia Road... while on the way to Import Monster to get my new shockworks fitted... Rolled through with the clutch in like a baws
surely to actually get the fine you have to have been a knob to the cop.
its like the dick head tax.
$603 for a loud XR8 my mate got done about a year ago.
f**ked i know.
    • Increasing overlap will bring the torque down earlier (and make your idle sound sick lol). Worth a shot (if you dyno time) to experience a bit (providing you are confident your valves won't kiss your pistons). Is to just take off 5 degrees across the boosted area of the map, and then retard the exhaust cam let's say, 3 degrees at a time and then overlay all the runs with VCT on all the way and VCT off as soon as you make positive pressure. Ideally you would have a total of 6x overlays to looks at 0 exhaust & VCT off once manifold pressure is +ve 0 exhaust & VCT on all the way -5 exhaust & VCT off once manifold pressure is +ve -5 exhaust & VCT on all the way -10 exhaust & VCT off once manifold pressure is +ve -10 exhaust & VCT on all the way Just leave your O2 wideband closed loop on for all of the boost area & RPM, and hopefully there isn't too much fuel correction needed and the Haltech is fast enough to compensate (I do this, then apply the correction to the main table). Getting that overlay data should give you a good indication of what to aim for.
    • So, my main limitation here is that the car does not have an oil pressure sensor by default, just a switch. As part of my tune I bought an oil pressure sensor upgrade so I now have access to oil pressure levels and logging rather than just the boolean behaviour of the switch but this means I need to use the tuning app to display this value. So, this rules out using any other app on the iPad. The app will also flash when pressure drops which is a nice feature. I have replaced the centre screen with an Android one, which is awesome for Android Auto, but I think it might be too far away and out of my line of sight. I might add some gauges to it this weekend and just see. I guess if its just temp and oil pressure I can make them massive! 🤣
    • This is what the look like normally. Except we only got the 2 doors locally
    • Back pressure is not really a function of the exhaust itself, but the turbine/housing. So the question/point remains valid. I would be fitting an EMAP tapping point and seeing what is going on in the exhaust manifold before committing to throwing boost at it. Flow. No intercooler is actually rated for continuous operation at any power level wrt temperatures, as they are no actually capable of shifting the required amounts of heat on a continuous basis. They get hot during a pul, then dump some of that heat into the external air (and some back into the internal air) during off load moments/periods). You probaby do need a bigger core, given the power level you're already at is somewhat above the "rating" of the cooler. Put pressure tapping points either side of the core (which possibly you already have, if you have a boost source near the compressor outlet and tapping near the throttle for existing purposes) and report on delta P across the core.   I haven't done the mass flow calculation to see where you would be sitting on the compressor map at the ~450is rwkW level we're talking here, but if you look just at the PR you're running at, which is ~2.8-2.9, then you have a really really wide swath of the compressor map to run in, and so long as you were making between about 45-75 lb/min of flow, you should have really good comp efficiency, with the ideal being betweem 55 and 65. I can't see the need to shift drastically on the map to get better results.
    • Welcome 🙂 The ER34 wheels and slight lowering suit the R33 sedan really well. I'm firmly in the 'keep it stock, at least on the outside' camp.
