Get well Hamish...
In other news... Aaron, can you repossess one of these and make sure no-one else bids on it at auction? :P
http://smh.drive.com.au/new-car-reviews/mercedesbenz-a45-amg-first-drive-review-20130828-2sq7w.html
  • Like 1
I'm telling you all once.... Make sure you have private health insurance. I have seen probably 25+ doctors and specialists in the last 4 days, including the head of neurosurgery. In the public system I nearly died due to not being allowed to see a neuro consult, and was left in a cubicle for 6-7 hours with no real assistance until I had a fkn seizure.
This will easily be a $10k+ hospital trip for Medibank (thank Christ I have the best cover available - commercial cover through NAB)
This is the issue we shouldn't have. The public system should be just as good as private, I just pay for it at tax time instead ffs.
I could fix the public system overnight by banning companies asking for doctor's certificates for single sick days. Bloody stupid wasting thousands of hours of doctors time filling out stupid notes so employers feel better. Spend the money on Hospitals instead.
Rant over....
Rant over....
Or stop people from going to the doctors for antibiotics when they catch a common cold, or a myriad of hypochondria.
I wasn't even aware of bulk billing until a few years ago, consequently never bothered seeing a GP for any minor shit, cause I thought it would cost me money. Someone awares me of how Medicare works, now I'm there atleast 1-2 times a year.
finding out if import monster have any TE37SL's in stock and if they do I'm going to try and get my deposit back from tyrepower hawthorn and go out and buy some straight away, I'm so over waiting and being stuffed around.
After spotting you other day, I'd suggest you to buy a set in 34 GTT size and we swap cars :P
TPH gave me my deposit back no worries, you'll be right
Well it looks like I might be going from TE37SL's to bronze TE37's - which will mean I won't be able to use the centercaps I bought as they won't match..
Either way I'm about to go there now and ask for my money back and then might go out to import monster and look at the bronze ones.
Get well Hamish...
Lol people ordering today will only get delivery in march, so a while off before repo.
But we are hoping to get a couple to drive around and play with soon, hopefully will be able to take it home. If I do, you know where I'm going ;)
Keep the caps as a reminder ;)
Lol well..
After going there they assured me Saturday they will be there - Monday at the very latest.
If Tuesday comes and I don't have them ill be going straight for the bronze.
so my bros gonna take the defect cos apparently he was 'speeding a bit' down eastlink prior to it lol still reckon he should of fought it - but doesn't want to get called out for speeding
ah well /skylinedefectlyf
Edited by UNR33L
    • Stock ECU (or more accurately stock tune) absolutely refuses to go over 10psi and behaves like you have seen. The Nistune is the same if it is the stock tune. If the Nistune chip has been tuned, the resulting tune could be literally anything for any combination of parts. The Nistune just makes the stock ECU Tunable.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
