I still cant get over A45 250kw from a factory 2L.
the day draws nearer when the pulsar can have its arse-handed to it by production hatches and will be the slow 70's hatch equivalent of today
It's wont happen with the reliability of Mercs it wouldn't be able to chomp a pulsar if it's on the back of an isuzu truck
Hmm have you sat in the back before? The front seats are awesome.
Back....okay at best....I wouldn't say roomy lol.
Lol it's not that bad man, even my coupe has a fair bit of leg room in the back..
2009-2010 depending on condition go from 70k to 90k..
2011-2012 go from $110 - $130k.
You want? There's a prestige auction coming up in belmore soon. There's a nice handful of them in there
link me to 70-90k amg c63 they must have high kms or be farked?
guys. clutch talk.
car will have around 300rwkw and will mostly be a week end car, sometimes drive it to work since its close etc.
I what is a decent clutch that wont break the bank? id love a nismo twin plate but yeah nah lol
would want it to be nice to drive and be able to take a beating when I track it..
its boiling down to buying the little things to finish it now :)
    • The spray cans were in the "Kiln" room whilst I was preping the parts,  so probably around 2 hours to get them warmed up, the kiln room has 3 small ovens running at 100°c, 3 medium sized ovens running 100°c, and the large one I used running at 80°c, the room itself was about 28°c, I also spent a bit of time taping up the parts in the room as well, and by the time I was done I would assume that the parts were around that 28°c As for power, I expect a couple of Killerwasps up high would be achievable with the current mods, I'm still running the MZR 2.0 intake and throttle body, and there is a slight mismatch with the 2.0 intake (smaller) and 2.5 intake ports (larger) on the head, this intake is matched and specifically designed to fix this issue with the ports mismatch, the throttle body is also a couple of mm larger, OEM is 65mm, the Bosch is 68mm In the end it will look "prettier" than the molded plastic thing that is the OEM MZR 2.0 intake As for the LSD, it's the OEM Torsen which works fine for what I use the car for, plus, basically no maintenance apart from the occasional oil change
    • I was at Tunehouse in Marrickville (great team over there really know their VR's) , and I spotted this Very clean R35.
    • Mate , I have the same issue right now with the exhaust noise , if you can tell me what your local guy did , I'll talk to my guys and see if they can do the same. Power is good but it just too loud when put it down.
    • The other trick I've found with wrinkle black is to put the can in hot water for a bit to warm the paint up, and to pre-heat whatever you're painting. It'll be interesting to see if you pick up any power with the intake, following with interest. Got a proper lsd for this?
