voted below the line earlier. was like doing an exam: you know the answer is 97, but coudnt find where the other 5 numbers had gone... even after a few revisions and a bit of scribbling, still couldnt locate the last 2.
Lumbar puncture results are in... Not what we wanted to see and I'll probably be in hospital for another 2 weeks minimum and another 2 lumbar punctures. Pressure in my spine has dropped but is still over double what it should be and white blood cells have doubled since last lumbar puncture, where they were already too high.
Starting to really play on my mind now which is why I'm talking about it.
On the plus side my private room balls harder than jay-z's bank account so at least that's something :/
Oh and in reference to the dog vs cat discussion we had a couple years back, my dog has sat on the top of the couch looking out the window waiting for me all day and all night for the last 2 weeks.
Every. Single. Day.
Stick that in your cat and smoke it
We still can't find the cause. It's most likely to be a virus we don't have a test for yet. And there is no prevention possible.
Leading theory is I was near some asshole that sneezed and caught it that way however the virus made its way into my spine/brain somehow. This happens fairly often (meningitis) however I copped the less common meningoenciphilitis which is of course worse.
you need to do a john farnham and take the pressure down.
Clearly... I'm on altitude sickness drugs (diamox) for that and we have remove a LOT through lumbar punctures.
Every. Single. Day.
I dunno, I don't mind cats at all, they smell less, break less of your shit and kinda look after themselves...
Probably best not to ask Alvin, Jonoe, Tony, etc which they prefer...
What would be the rough cost of re-spraying my front bar if I remove it and disassemble my self? In northern suburbs - any suggestions?
Problem is if it's off the car, they'll have trouble color matching and blending to make it look right :/ If you don't mind, and provide them with the paint codes, I dunno maybe $3-400?
Are you capable of prepping the bar yourself? Sanding, Primer, etc? 75% of the work is in the prep...
Good point, I didn't think they'd have to really blend considering it's a different panel. I guess I'd just take the whole car in, I just don't trust some of the shops around here a)working on my car b)having access to the keys/alarm/etc for "later use" :/
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
