I like this guy
If you're feeling lonely at Cabrini lemme know and I'll come in for a visit...we can talk about the rise of west coast hip hop or something.
And if the missus needs any help with anything at home or the little one, gimme a yell...I'm only a suburb away at the moment.
Hope you're out soon.
I dunno, I don't mind cats at all, they smell less, break less of your shit and kinda look after themselves...
Probably best not to ask Alvin, Jonoe, Tony, etc which they prefer...
KHIKYG
https://www.facebook.com/simon.henman/posts/10151544070386148
Please like and share my post, need to get this message out
I typed up my own.... I figured it's probably more effective to have political messages without swearing
thanks man! visit would be awesome
i'm at st vincents private though :)
Damn took a chance on ol' Cab
Off Grey St? If so, I was there today getting radiology. Due for cortisone appointment on the 17th, but I'll come past early next week or something.
/hospitalisedaustralia
b)having access to the keys/alarm/etc for "later use" :/
1. Photos of everything before you drop it off anywhere, inc tyre tread ;)
2. If you've got a powerfc or similar, drop the rev limiter to 4000rpm... When mine went in to a panel shop to get a new door / resprayed, set the limiter low and then drove it to them... Hell I could have set it lower than I did, but it was enough to stop boost coming on... or my tyres being fried like a mofo.
What would be the rough cost of re-spraying my front bar if I remove it and disassemble my self? In northern suburbs - any suggestions?
$350ish.
Carlission bodyworks in coburg.
Speak directly to zayn or huss.
Both very good friends of mine
Mohsen sent you
I only got 3.7k this year :whistling:
inb4 dezz trumps me
Can't remember what I got this year but think it was more than that. Not as much as last year though.
Got nothing on the people I know getting ~$10k...
back to LPG, my mums G6 is straight gas, and the tank takes up where the spare wheel would normally be. LPG tank must be bigger than petrol tanks (in physical size not necessarily volume), or can't be mounted as low as a fuel tank maybe..
I've tried the whole election to avoid being political, but I couldn't handle that bullshit that has happened this afternoon / evening...
How can the Communications Spokesperson not have read the Policy until the afternoon of the release, why was he not directly involved in its creation?
How can he defend the Policy, and then come back a few hours later to after the backlash to try and say that it was badly worded?
It literally said the opposite of what he spoke of on the radio... If it was just badly worded then surely he, as the Communications Spokesperson, should understand that that is not the party stance on the issues?
I just don't understand *shakes head*
unaware of anything happening in the world....
Do my 12hr work in the middle of nowhere, shut the f**k up, eat dinner, go to sleep. Repeat for 9 days straight.
bushfire near the equipment today and some massive storm coming through now
how is that going? i bought an aquamist hfs3 setup but never went through with it.
How do you make the water:meth mix?
it was going fine, its all in pieces in the garage now.
the water meth mix was easy to make, get a glass measuring container, measure out a volume of methanol and the same volume of distilled water, add to tank. if adding nitro methane to it ~125ml nitro methane to 1L of water/meth mix (should result in ~30-50hp increase, a little more nitro meth can be tollerated but not a lot, too much can just make the whole thing hard to light.)
Let me know when you're going, I'll come too!
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
