compounded per hour
Need to purchase some wheel nuts to fit my 'temporary' wheels so I can give Tony's wheels back.
Stupid me for grabbing AVS wheels...
what do you need? I might have some stuff lying around
PS I have a full set of ProjectMu wheels nuts TO BORROW.
If the Project MU wheel nuts do not return to my possession I will HUNT YOU DOWN WITH A KNIFE
:P
compounded per hour
:P
Hehe, after 17mm nutswith narrow hex bit (not sure what they're called).
Can lend you my 17mm advan nuts grant
Hmm... Will try tyre shops up in north first and FB you if I need them.
wasteland newb here, herro to all! so this came in the mail today. :banana:
Welcome abroad, strap on, it's wild ride in here!
That is one shiny car brah
Tradition on here is to take a shirtless pic in the reflection of your car
So we know how good your detailing is
nohomo
You guys know me too well.
Only 2GB though, where are all the other ones?
Sold on the black market. I believe Aaron was the buyer
Good to see the FBI joininh SAU VIC Wastelands
What model Skyline/Evo you drive brah?
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
