yeah but she has never run out before
It was weird when it happened, it was like she had this huge gust of energy, but she was really out of it from all the seizures so she ran off
while she was down the back we couldn't even pat her cause she didn't really even recognise us, would just growl and if you got to close try to snap at you
Nick dude, I'm probably gonna get flamed for this, but why didn't you euthanise her? It sounds like she was sick enough for it to be justified.
Good luck with her I really hope she turns up or at least passes peacefully. Dogs are family members.
Older brahs.
Going through a crisis.
I dont want my car anymore.
Im considering stripping it.
Ill keep the wheels, skirts and pods and rb26 but sell all the other shit.
I used to love that thing so much. Doesn't seem that important anymore.
Haha good ol' Mohsen.
In b4 he sells the lot and buys a vl :P
strong future aware.
The thing is were we about to that day, we knew she wasn't getting better so we were going ot take her back to the vet that night
But then she got up that morning and took off, it was the weirdest thing. As if she knew we were going to take her
Thanks though man. Yeah they are, they make such an impact. But even in her eyes her personality had gone :(
we euthanized our German Shepard after she lost control of her hind legs. Loss of control happend so quickly, could no longer move after 2 days, whole episode happened quickly.
I could imagine it would be a much harder decision if you have a hope to prolong it etc
who's on optus here?
i've been on telstra only for years now, but optus have readjusted their plans to be somewhat in touch with the current technology (more data)
well....you know my issue with optus lol
I decided to stay with them after their offer through ombudsman.
Will stretch it out a couple more months & transfer to telstra
Ah k, fair enough man. My family have probably spent the better part of 100k on pet bills over te years...we're all for doing everything we can for our loved ones...but we also recognise when we're fighting a losing battle and know when it's time to make the call. Have had to put down at least 4-5 dogs...it never gets easier. Memory issues are fking sad too, like Alzheimer's in humans...terrible disease.
Just remember the good times, as they say. Knowing and remembering that you gave an animal a good life before it's passing can be a reassuring thing. Talking with family members about your memories with your pet, is also good catharsisism.
She wasn't declining so we were hoping she would improve but it didn't happen
Yeah that's why we were hoping she would improve, to prolong time with her. But we knew we would have to euthanize her, but then she went weird that morning and ran off. It's actually worse not knowing where she is or what's happened to her than having to euthanize her, at least you can bury her at least
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
