Krispy Kreme doughnuts taste awesome; f**k off back to your respective Starbucks / Coffee Club locations, hipsters.
incorrect. i don't frequent those shitholes either.
kispy kreme is shit, it's a fact...
Just ask this independant scientist
I has a small womans pirate suit?
Need to confirm if her suit will fit
If you could contact ask her that would be great
Birds = legend
That is all
I thought Will Smith proclaimed himself as the Legend
And booked in at RacePace on Tuesday for dat dere ethanol tune. Brb with awesome power or a popped engine.
Take me for a joyride after that pls
Edit: If you know what I mean...
His sons a dick though, every single picture he looks like he's staring into the distance trying to take a shit
lol there's another actor who never faces te camera in his movie posters; forget who it is.
Made it to knox and back, alive.
You guys hype it up too much
He was in the northern suburbs/northern vic today
Mohsens mate go defected in a 4wd for no mud flaps and Michael saw him heading towards Bendigo in Heathcote
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
