Someone needs to enlighten me on some of the pricing of foods in these Japaneses restaurants
I'm sure Hamish/Alvin knows
Particularity the pricing of sushi & sashimi
Don't get me wrong I love japanese food but where some restaurants you pay $15-$20 for a few pieces of sashimi. Im like rightio
It's a raw fish so not much prep if any is required?
So which then leads to how much cost variance is there in the quality of fish?
Because I can't taste much difference...! Between sashimi in an average restaurant and a high end one. The plate just looks prettier with a few fancy things on the side.
i just go to suzuran, and get my sashimi blocks now. i'm getting lazy. and i dont really want to deal with anything other than salmon/kingfish/cobia belly.
I love that attitude that people get when working for prestige companies...
Oh I would never drive less than a Mercedes... Even though I earn 60k and could never afford one...
Same goes for Louis Vuitton shop assistants etc
  • Like 1
lol I know
Everyone here hates chryslers especially, I love it when the comments come from the people that don't even have the slightest idea about cars.. You just laugh at them
Chrysler Neon is where its at. cult following in mericas.
good ol' NFS Underground days
jks, its a piece of shit. but would play that game if they ported it to iOS. still play Tony Hawk 2 on my phone, kick flips are bawla
gents and kents.
anyone got air con and window tinting hookups in south east?
Car air-con or home air-con?
If home I'm getting some units installed this Wednesday via a SAU member
thinking something similar to this soon...
Do eet!
Do eet!
car man..... sounds alright with the home stuff? he doing you a good discount?
Haha sure. Still learning the clutch a lot lighter than I'm used to, and about double the power of the 626 it's replacing
:D. My friend was looking to get one of these too (albeit sedan)... they look quite nice! Leather interior and comforts, yet grunt where you need it :P.
Lol lighter clutch AND more powah. Dat daily?
Lol had it all set up for the delivery but missed the mark.
Birds came in and salvaged what was left haha
Or perhaps I set it up for Birds, I know he loves his quips. Just call me the puppetmaster.
Yup daily duties, has a decent tow capacity too :) Parking was interesting this morning though, very light steering.
Will be calling vicroads shortly to find out what hoops I have to jump through
Preparing my anus for this summer
My mind doesnt usually sit in the gutter, but read this the first time round. thought you might have been referring to power bills.
Good new from Vicroads for a change! *celebrate*
If your car has been engineered/new engine number, and you have put a different motor in it... all you have to do is go to Vicroads, tell them its the same engine as the engineer, have a signed piece of paper from mechanic with new/old engine number and they'll change the details for you. So when cop checks cert, tell them to check their system details and it should all be there. wew.
Inb4 defected for everything anyway.
as long as the number follows the same sequence as stock... e.g. RB25xxxxxxxxxxxx
this is boss when you get situations like an AE71 with a 4AC motor and the numbers are just 4Axxxxxxxxxxxx and a 4AGE is also 4Axxxxxxxxxx
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
