Hahaha
Congrats Paul, now to strap on a big single t04z?
Missed you up at qld brah, seems when ever i facebook msged or got one back from you i'd be on the piss and forgot to check my phone :P
How'd you guys go anyway?
I think the poor organising gives you some idea of the drinking involved haha. So loose
yeah figured we were doing the same sorta thing lol
we hit up that big kart track a couple of hours north, bit of fun the track felt the size of winton
Edited by UNR33L
guess ill have to drive one sometime to see what the fuss is. factory recaros sounds nice, probably still factory heavy though.
Guy i know through work has a modified one in Tassie.... always been tempted to buy it at Tassie price, drive for a bit then sell for profit here. who says JDM styling is a bad thing :P
Wouldn't buy any car from Tassie after knowing what panelshops would do and send down there and the dealers would sell
Lol immigration.
will have to do this soon, the new EOI system is quite a pita isn't it?
I've also got to go for IELTS, but me no spik engrish.
Going through it now with Maggie, so far no issues. However it's a long drawn out process now, about 3 years
@Plattsy
Mate of mine is going through a super hard time for his PR currently and he is from the UK as well
Seems my engine has a restriction!
Making 260rwkw on E85, only 8rwkw up from my 98 result...albeit with good gains down low and in the midrange. So something is choking it up top. RP and I suspect it may be the cat converter, so tomorrow it's getting made more "functional" and then retuned.
Could also be return flow cooler. Could also be turbo too small. Could be any of the things that make my car look as stock and legal as possible. Not fussed about top end; I switched to ethanol for the awesome mid range, but would be good to walk away from the exercise with a few more ponies up top if we can sort out the restriction.
The guy is like 40+ and had it since brand new. Even though he only has one functional eye, he can drive.:P
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
