Wow Rb 2.8 Neo
Don't see stroked Neo's everyday
Good ol hypergear turbos
I got a ss2 at the moment thats a restriction. Im thinking early next year ill just go a Garret 3582, ext gate
I got a ATR45 sitting around that came out of my test car which you can swap for trail, that turbo is made as a XR6BA replacement so works identically to a 3582 and maxed out at 445rwkws on E85 externally gated. It will bolt up to your current setup so nothing needs to be modified apart from two silicon hoses. PM if interested.
Gta online.
My god.
Funniest thing ive seen in a while.
Oh man.
Minding my own business walking on the road. Some guys in a cop chase. Almost cleans me up.... then the cops clean me up bahahah
GTA V online is mint, me and a few mates were just running around causing ruckus
(PS4)
I know right?
I was on last night...me and a few mates made an improv motorcycle gang for the lulz. Went around smacking up cars and shit; just minding our own business. Then some flamin mongrel in a 4WD ran half of us over.
I know right?
I was on last night...me and a few mates made an improv motorcycle gang for the lulz. Went around smacking up cars and shit. Then some flamin mongrel in a 4WD ran half of us over.
i loled
Stao radar on whenever turbo is mentioned haha
PM replied
