so flights eh...
you want noise canncelling and not use very often get the Sony Noise cancelling, they are quite good for the $$. mine were 60ish
ir do it properly Bose QC15 or what I got Sennheiser PXC450
http://en-au.sennheiser.com/high-end-headphones-audiophile-stereo-pxc-450
nothing comes close for noise cancelling and comfort as if you going to waer them 15+ hours on one flight that is very important, also good for working in data centres.
regarding what to bring on the plane, table is the best these days,
has games, I have 100's of hours of video plus 6000ish books to choose from and is lighter than carrying one book.
plus most decent airlines now have power in the seat so you sorted.
but then what would I know.
seriously f**k google.
been asking for months to use my real name from my "legit" email address on my youtube account. been trasnferring my avatar to my email without permission etc. then created a youtube account for my gmail account because I didnt want to merge, and now its merged them anyway. and you cant deactivate shit.
f**kin tards. go eat some dream boats you chumpy ass faggots
duckduckgo has the right idea, but doesnt find what you want.
so flights eh...
we all cant fly business class, im lucky to get some fabric on my seats, let alone power :P
Just did a 5hr flight from Singapore, read a book + had 3 seats to my self, so went asleep across all 3. #betterthanbusinessclass
ok domestic don;t have power, but all tables have power that lasts more than a flight.
International, Qantas in all 380's and most 747 have power in cattle class.
and I don't get business class very often.
over 8 hour flights Premium under 8hr cattle.
Unless airline is feeling nice..
http://staticice.com.au/cgi-bin/search.cgi?q=PXC+450&spos=1
and about $350 on ebay but possibly weird grey imports... not sure what Sennheiser's international warranty is like...
  • Like 1
Yeah YouTube has been hassling me to use my real name. But I do not want. Have they forced it now?
yep.
need to get some steak off you.
what do you need?
the cape grim scotch dry aged was nice, heaps nicer than the mb4 sirloin, i know what i'll be buying next.
Had ayam and ikan set from Indo BBQ in Orchard today...dat fish ruined by dat stingray.
why you guys eating at orchard road anyway? food's mediocre at best.
Edited by xALmoN
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
