errrrrggghhhh got z32 afm today. plug didnt match one i had.
same diameter as z32, but different plug. Pretty sure it wasnt RB25 though... we were pretty puzzled. Found a Z32 afm plug, but had 1cm of wire to join with *sigh* get new pins on Monday and wire it properly. another week setback
Hmm urite, just went out with S2 RB25 afm to compare the two, is actually exactly the same down to part number the sticker colour had just faded. Looking at it the other day I thought it was bigger and just assumed it was same as z32. Good news for S2 25 owners though looking for a cheap AFM for troubleshooting. S1 A32 Maxima.
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
