Are you serious about turboing the micra?
yup. not for a while tho.....
Ceramic wheel 32 GTR turbo? Naice.
Lets bolt it on Platts. :)
they are gtr, not sure if 32 or 33 tho....
and not yet dude.... gotta rego and rwc the pig first!
have to find a way to deal with fuel pressure, but the car will run 5psi with out anything else.... doesnt need injectors ecu anything. just zaust and manifold.
hahahahaha.
Like the mech will pop the bonnet for rwc. lol.
hahahah. if you gotta dodgy one then im down.
if not, it can wait. knowing you, youll wanna put all sorts of fancy shit on it, flux capacitors and the like.
I could think of a few mods...
What can you knock off from work? :P
hahahahaha. i got a few tasty things in here at the mo, but they are leaving in an hour. no chance of knocking em off!
When he sees Paul he will check that it's not an explosive
you saying i look like taliban my friend.....
At least then it might do 88mph
hmmmm still might be a push.
They're 33R.snails
still ceramic tho?
Yup still ceramic, I guess you could always chuck an ebay N1 rebuild kit through the broken one if you wanna shove more boots in :P
thats a good point!
but i doubt ill need any more power than stock mate-torque steer is a killer.
and the only lsd avail, is a nismo one at about 4 grand.
For me, fishing is not about catching fish, it's about hanging out with my mates in the sunshine with an esky full of beer and talking s%#t
Though... This is the last fish I actually caught... Was a 14kg Mahi Mahi... Gave it to the place I was staying at and it was cooked in a traditional oven underground and fed everyone. notbad.jpg
428392_10151358304916746_2082240263_n.jp
http://upload.wikimedia.org/wikipedia/commons/c/cf/MahiMahi-bull.jpg
mahi is 9kgs max. defs not a 14kg. just sayin.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
