anyone know where I can find some of the white clips that clip side skirts onto the body for r33 gtr?
also the boot interior clips?
went to Nissan Blackburn - they sent me to their warehouse in Mitcham, they didn't seem to be able to help me, ended up with some clips for underneath plastic below front wipers which MAY fit..
but yeah still searching for a few..
Sideskirt clips
Skirt side http://amayama.com/search/?q=G7656-13310
Body side http://amayama.com/search/?q=76848-35F00
Boot trim clips http://amayama.com/search/?q=01553-04941
Hopefully the sucker fits Alvin, I did a fair bit of cutting on that front pipe...
If not I can just make a new bracket for it.
How does it sound mate? I asked Grant that question after doing his exhaust and he just stared blankly at me and chuckled. :unsure:
speaking of exhausts.
have you been under the back end of an evo x to see what kind of muffler space there is infront of the rear diff?
i was thinking a moderately sized muffler infront of the rear diff, a Y pipe with one side going to an electronic cut out valve then a pipe to the right tip and the other continuing the exhaust through a big ass muffler and then exiting the left tip.
so like a varex but better sounding.
I am making a similar setup, but I want it automated, so I ran a vacuum actuator.
https://www.facebook.com/photo.php?fbid=623719741023434&set=a.448399381888805.111313.448396628555747&type=1&theater
I haven't been under an Evo 10 yet. Sorry mate.
has that been tested/run yet or still in the process of making it?
the fact that it automates itself is cool, the same could be done electronically with an RPM window switch
Untested as yet.
I wanted it wide open on throttle, if the vac setup isn't great I might run it off TPS.
Where HAVEN'T you travelled to?
lots of places.
this is my list been to atm
(lots of places are multi trips tho)
Australia
Fiji
England
France
Sri Lanka
new zealand
Vietnam
Hong kong
Macau
philippines
South korea
Wales
Ireland
Morroco
USA
Germany
thailand
laos
Brazil
Argentina
vanuatu
Italy
Vatican city
Sweden
Canada
South Africa
Singapore
Greece
United Arab Emeriates
Spain
Austria
Monaco
Got palns for a few new ones next year.
Kuwait is looking good.
Maylasia low chance.
Pakistan..not sure if want to.
Egypt 50/50
Mexico high chance
as well as back to some of the usual suspects.
Macau want me for 6 trips, so lots of side trips to hong kong
USA a couple times
2 more trips to brazil, if so thinking of doing a side trip to Argentina or Chili
oha dn Thailand and prob SG
no idea what else yet
    • Assuming the current ECU is stock, it might be worth getting hold of a nissan data scan cable. It could be as simple as voltage at the ECU
    • You need to test for spark when it matters - ie cranking. Kill the fuel supply, pull a plug and earth it, set up a camera and go crank. The spark needs to be consistent, every other turn of the engine. Not some sputtering of occasional spark. The reason I say this is because spinning the CAS in the air is not the same as spinning it installed, and if there is a bearing problem in it, the disk might work differently in the air than in the engine. You won't want to try to set the timing unless you know the spark is happening right.  Also, reconsider running the R35 coils against the stock ECU. They like a different amount of dwell cf the originals. It's not massive, you can actually run them, but it is better if you can adjust the dwell (which you can with Nistune in the stocker, or with an aftermarket ECU). Besides any of that - when you had the multimeter out, have you got power where it needs to be, earth where it needs to be (and when, in the case of igniter triggers), etc?
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
