lol @ a little
I remember taking 5-6 attempts at shaving off material to make it fit. My reo is now cosmetic. I don't believe the fkers who say they fit a fmic without chopping into something!
Mine bolted in with no reo cutting. But it's an apexi fmic designed for r32 haha
Pulsar still unfinished?
affirmative.
Having issues with airflow... turbo is pulsating at idle. Everybody is scratching heads at the moment.
could be out of balance throttle bodies, turbo (while simple, it was rebuilt during build), people are pointing fingers at cams and JUNs lack of info on cam card.
I dunno... will let the pro's sort it out.
After doing some reading on the complexities of the vacuum and hose system on the intake of the GTiR (hooray for Nissan and clusterf**ks), I am liking the idea of a BOV and recirc all those damn hoses. It really is a mess.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
