Yeah I've had a look but there's just so many restaurants, and a lot have conflicting reviews. I thought it would be better to ask the locals.
google reviews count for jack shit these days got to experience stuff for yourself happy people usually make up the silent majority
i was going to suggest a few places
but then saw vego..
no meat
no fish
no good places.
All the vego places I've tried have been oily and just wrong combos.
So Not that I have been to this one but my sister in law swears by it:
http://www.au.timeout.com/melbourne/restaurants/venues/221/moroccan-soup-bar
and my sister used to go here: (till she moved to perth)
http://www.au.timeout.com/melbourne/restaurants/venues/1476/attica
Hi friends.
Recommendations for good places to eat in Melbourne? So far I haven't been anywhere too great...
  • Lentil As Anything
  • Address: 41 Blessington St, St Kilda VIC 3182
    Phone:0430 388 984
    Hours:
    Sunday 11:00 am - 9:00 pm You pay what you feel its worth, best atmosphere in Melbourne, everyone is your friend !!! (vegetarian only)
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
