overrate
əʊvəˈreɪt/
verb
past tense: overrated; past participle: overrated
1.
have a higher opinion of (someone or something) than is deserved.
"an overrated player"
synonyms: assess too highly, overestimate, overvalue, rate/prize too highly, think too much of, exaggerate the worth of, attach too much importance to
battle
ˈbat(ə)l/
noun
1.
a sustained fight between large organized armed forces.
"the battle lasted for several hours"
synonyms: fight, conflict, armed conflict, clash, struggle, skirmish, engagement, affray, fray, encounter, confrontation
burgers at home are just as quick and easy if you are prepared.
I buy all my fresh fruit, veggies and such from the market for the week and then get 2 weeks worth of meat from Tasman.
I always buy a bulk pack of premium mince and prep it for burgers.
I also go to Breadtop and buy 4-5 packets of savory rolls at a time and throw the packs in the freezer.
These are the absolute last word in awesome home burger buns and aren't even a little bit effected by the freezing process, just in the bags they already come in. they are small though, so you need to eat 2-4 each
The good thing about Tasman is that the way they pack their mince is directly from the mincer to the pack, so all the meat strands (and hence protien strands) are aligned and when not mixed up make unbeleiveable burger patties.
I get the mince and lay the strands (all facing the same way) on gladwrap to be a little bigger than the size of the buns and roll the shit up nice and tight to get a perfect pattie shape but with all the strands facing the same way. using a LOT of gladwrap.... a LOT
make a few logs and throw them all in the freezer too.
this process take like 5 mins at most.
To cook them, just remove from the freezer and once thawed enough cut into thick pattie slices (with the gladwrap still on and using a SHARP knife) and lay on bench to thaw properly and at room temp (doesn't take long after sliced)
heat a thick pan or the BBQ until red hot, salt the meat heavily with sea salt flakes and cook (still with the gladwrap on)
as soon as the gladwrap gets near the heat it shrinks and doesn't actually hit the heat and melt, cook one side, turn over and remove the gladwrap.
cook until still medium... and you have the most awesome burger pattie imaginable
Then I always ensure I have a pack of bega super slices in the fridge at all times (epic American burger style cheese) and can have burgers with minimal notice at any time.
the rest I change up based on what I feel like...
YouTube, mr chef, pls
overrate
əʊvəˈreɪt/
verb
1.
nice try junior... ain't no one going to side with you that food considered better than macdonald's is thusly overrated
too much effort lol
mac·ro
[mak-roh] Show IPA adjective, noun, plural mac·ros.
adjective
1.
very large in scale, scope, or capability.
2.
of or pertaining to macroeconomics.
noun
3.
anything very large in scale, scope, or capability.
4.
Photography . a macro lens.
5.
Also called macroinstruction. Computers. an instruction that represents a sequence of instructions inabbreviated form.
buy american cheese slices from costco fgt, not like I haven't seen you there
Also who can translate the diagram for me, needs to be specific
Most I know of but need to just double check and there are no English instructions for boldworld kits :(
Any parts in particular you need or the whole thing? Might be able to get a bloke to go over it.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
