what cars are in the 15-20k bracket that fit the following, looking at cheaper options to see if any grab me sufficiently to sway me from the 35k+ evo x
small/medium sized car, dont need a land yacht.
Turbo (minor mods will net ~200kw+)
decent factory options (if they have them and what), cruise, ok stereo, auto wipers/lights etc
fairly new 06+
can be had with fairly low km, 50-80,000km
so far the list is
Ford XR5 (5 cyl volvo engine (do rate), only comes in manual)
Mazda 3 MPS (good engine, bit laggy but makes butt loads of torque, only comes in manual)
WRX (has boxer engine, dont mind the sound, but not sure if i want that sound ALL the time)
Ralliart Lancer (Has DSG ONLY, but from owners of them i have been told the suspension is quite pedestrian as are the brakes)
MK 5 Golf GTi (Has DSG option, almost all have 100-150+ km, not the best of the GTI models, engines are a bit weak if modded much)
fairly new 06+
so far the list is
FWD is for teh gheys....
If after reading this your list has narrowed to 2 options, that is acceptable
If it is narrowed to 3, then GTFO
For that bracket/specifications he'd only have WRX, not STi though... I don't mind the hatch look itself. WRX was gonna be my suggestion, though.
Golfs, would only want an R really but they're more monies... same with the Sirocco (also it's fwd... should have made it awd like the R)... maybe mkv R32 or GTD ?
Thought about any euros besides the golf?
Not sure on prices, and they're probably into large car territory, but fg f6 is pretty powahhh. Or maybe xr6t?
Or you know... Just buy the X :P
MPS certainly doesnt float my boat, even though im FWD biased. Ugly, large, relatively heavy and somewhat complicated engine from what I can gather.
XR5 turbo comes recommended, but I'd go a bit further and go volvo personally. 3" inch straight through, tune and LSD and you're done
whos the biggest wanker here...
the gym wanker with spindles.
the bro curling wanker in the back ground?
no its the phone wanker in the gym. f**k you mate.
closely followed by everyone who ever went to a gym.
Xr6t , don't mind them but it's large and I don't need a car that big.
Haven't looked at other euros, don't want anything horribly expensive to fix though.
2 votes for the wrx hatch
2 votes for the xr5
my vote only counts for WRX if STI - otherwise vote defaults to evo 9 which I added to your list whether you like it or not
from what I understand it's a BP motor, same as the mazda GTR. That being the case it would be pretty to get 200kw from with no issues, and at 1 tonne that's pretty damn fun!
what's the gearbox like though, is it made of glass like the GTR?
Lol why so much hate
Go to the gym, do your thing and go home.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
