Shit lad you ok?
yeah... turns out it's just s flesh wound... i managed to hit the branch which took the brunt of the force out of it (thought this may have been bone) and also gloves took a little too.
very sore but not going to lose any movement or require surgery.
Am I gonna get defected? If not, I might spend the day putting my car back together... hasn't left the garage since Sandown, and its misfiring randomly on cruise :/ Needs plugs I think
I have a stamp pass guranteeing no defects
One of the girl's from work got dropped off her by her husband in this today:
http://www.skylinesaustralia.com/forums/topic/405604-genuine-r34-gtr-tommy-kaira-immaculate-reflections-detailed/
Love to know how it got compliance when it was a 2.8 stoker from JPN
Either it wasn't inspected by someone from Canberra or it returned stock for compliance.
Am now at the 1.5 hour mark of phone calls with Virgin Australia + Expedia...
All I'm trying to do is book a Virginal Australia flight from Melbourne -> Sunshine Coast, using credit I have from an existing cancelled Virgin Australia Flight.
WHY IS THIS SO DIFFICULT?!
NEVER EVER EVER DEAL WITH EXPEDIA FOR ANY HOLIDAY! EVER!
Edit: First call was 3:07pm, got off the phone at 5:45pm... and they're going to call me back "within one single hour" after they've sorted out their s**t with Virgin.
Expedia can suck a donkey bratwurst
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
