6 months ago I was talking to a Treasury Estate rep who said they were trying to push moscato onto the younger crowd. I made the prediction that one day it will make it's way into nightclubs as an on-tap, women's counterpart to the men's cider craze. Canning it is half way there. I wonder if my prediction will come true...
I confess to liking moscato and late harvest. If I recall correctly, it was originally pushed as a nightclub/bar drink but never took off. Maybe the timing wasn't right or they didn't have the marketing of today.
Juliette has seen it on tap already....
I understand sharing beers regularly, but drinking beers every night is a pretty bad habit. i know a few of people who drink almost 3-6 beers every week night, and they see it as ok because tradesmen and because alcoholic. But living a hater/hipster/father lifestyle, I thought of it as an oddity.
no, it's an awesome habit... because beer is awesome.
Been on the Oetty's for a while now
http://danmurphys.com.au/product/DM_914086/oettinger-pils-bottles
$29 a slab and I drink a slab a week
based on DM's full price for draught that's a saving of $830 per year for a better beer with no preservatives.
f**king win
Ok, off to dm's
But still need to get moar cash for a plane ticket to Germany for Augustiner Brau.
the cans are a surprise.
but i do like their moscato. pretty pricy though
farkin alvin, moves his dinners so some one can go, now i cant go! ya big bummer!
nah all good mate, ill chat the next one.
So I went looking for some new and engrossing movies to watch and came across this list... then realised that I've seen about 90% of them :/
http://couchpopcorn.com/2012/10/02/20-best-mindf**k-movies/
I've just gone though a comedy phase, and then a infection (non-zombie) phase and now sure where to go from here...
I'm thinking of hitting up all of the Studio Ghibli collection, unless you guys can suggest something that I just should not miss out on seeing. I don't like slow movies, so if its fast paced and engrossing I'm into it :)
k go...
i like slow movies, so cant really help. sorry.
in other news, if Aus did industrial estate sprints, i'd give it a go
I fall asleep or get distracted too easily for slow movies...
Good luck getting a permit for that on the streets, glorifying street racing in industrials would bring all the boys (in blue) to the yard.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
