Hey tard muffins,
I'm having my Annual Australia Day BBQ / Triple J Hottest 100 Party on the 26th (obviously)
All you regular wastelanders are invited (especially if you own a 34r and would like to come have a chat with Birds) to come and chill in the sunshine with a few beers and talk some shite :)
Let me know if you're interested and I'll add you to the facebook event.
Cheeeers
will come after work? lol assuming its still going on.
Hey tard muffins,
Cheeeers
I'd like to come to this
<br />speaking of dream boats<br /> <br />what the fark is going on with your car? longest build <br />ever.
<br />Life keeps throwing curve balls.<br />Now have to look after the house, mum and sisters. So hardly any left over $$ for the car atm.
some people just want to watch the world burn..
for the uninformed is JJJ one of those am stations?
It's past 105.1, and there's no need to ever go past 105.1 on the FM band.
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
