Hey tard muffins,
I'm having my Annual Australia Day BBQ / Triple J Hottest 100 Party on the 26th (obviously)
All you regular wastelanders are invited (especially if you own a 34r and would like to come have a chat with Birds) to come and chill in the sunshine with a few beers and talk some shite :)
Let me know if you're interested and I'll add you to the facebook event.
Cheeeers
will come after work? lol assuming its still going on.
Hey tard muffins,
Cheeeers
I'd like to come to this
<br />speaking of dream boats<br /> <br />what the fark is going on with your car? longest build <br />ever.
<br />Life keeps throwing curve balls.<br />Now have to look after the house, mum and sisters. So hardly any left over $$ for the car atm.
some people just want to watch the world burn..
for the uninformed is JJJ one of those am stations?
It's past 105.1, and there's no need to ever go past 105.1 on the FM band.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
