The ralliarts are ok, it's just standard lancer with a nicer gearbox/engine and evo 9 awd
Brakes are very much street spec, don't expect them to handle much spirited stopping before fading, suspension/back end feels a little nervous in higher speed corners. Disregard what the gearbox service intervals are in the manual , 40k km or less if driven hard and then change the filter and oil.
Mum just bought a 2012 Honda Vibe-S. Such a cute little car and I never thought i'd say it but it has such a nifty, useful interior: loads of room for such a tiny car. VTEC will kick in on the way to Coles for sure.
In other news, PowerFC tune booked in for next Monday @ Chequered, can't wait!
Curious when you sent the original booking message and how long they took to reply
Im also trying to book my car in lol, considering going elsewhere if it takes too long
Cat took a while to reply to my first few messages, but they have just gotten back from Xmas break and apparently had like 200~ enquiries over that period lol.
Try calling instead of messaging!
Yeah I know they just got back from their break
She normally replies in the order she receives the messages
So was just curious when you sent your message so I have an idea where I sit in the queue :)
Sent 1st message last Wednesday, didn't hear back for 2 days, got impatient and called.
Jumped the queue? Maybe.
10's start at double what a standard 7 is worth.
pretty sure this is what he meant by trading up ;)
They are a good option if you were going to buy/lease one new and novate or salary package.
As a second hand car and something bang for buck, 10 doesn't come close to 7-8. 8 with the 6spd is currently best bang for buck imo. 6 months ago it was the 7, but the 8's have come down.
Just have a look at prices of 9's they are stupidly expensive.
and this is exactly why I have a 7
build my simulator you ass
you want a simulator of scott's ass...
even for you that's gay
anyone been in a current ralliart?
what's the interior quality like? I know it came out 4-5 years ago, has it had any updates?
Madden's brother has one in Brissy.
It's an ok car, but requires a tune big time. There is no power what so ever under 4K, they have neutered the poor thing.
Also fuel consumption is not a strong point (13L/100 is their average).
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
