You can buy duty free from Singapore and bring back to Aus, I brought in 2L of vodka. It's best to buy your alcohol at the stop immediately prior to your final destination as if there's a stop over inbetween you may not be able to board your next flight with it.
Edited by L33SH
A mate just came back through there, claimed he couldn't bring anything as SG --> Aus was not allowed. I was skeptical to say the least
I think it has to go through checked baggage rather than carry on, or vice versa.
Rekin couldn't bring back a 40oz of Absolut which he purchased on his way into Singapore, so he left it with me when he went back. This might have been because he had no checked baggage.
I remember now...you have to take it back as checked baggage, but you can't access duty free shops at Changi until you've checked your baggage...so you have to buy it as you are entering Singapore rather than when you are leaving. And pack it in suitcase/checked.
Fair enough. Guess my mate is absolved then
Thanks brah
Can any brahs confirm if you can/cannot bring in duty free liquor from Singapore
now here a topic I know well..
Singapore is one of the few countries you can still buy duty free and bring it to aust after buying in the airport.
you need to be there early however if you buy last sec they wont sell it to you as they don;t ahve time.
YOU buy the alcohol, and they bag it
give you a ticket.
you then go to the gate, go through security
Go through the LAG check that is a solely AU requirement,
and after the this you give the attendant in the boarding lounge the ticket and you get your bag.
remember you cannot carry on any liquid more than 100 ml onto a flight to AU international
unless they do this check.
HK/Bangkok do not offer this.
Dubai does a variant of this allowing you to buy.
not that I've done this b4.
Melb arrivals Duty free prices...higher than dan murphy's usually.
Customs asked me if I had any pharmaceuticals/steroids disguised as shampoos etc
I said "Nope"
He said ok exit through there
Next time I'm bringing in all the steroids
Should have grilled customs
This is all naturale
Just becuase I look big doesn't mean i take steriods
Do you even lift?
Police Ten Seven; a New Zealand based road patrol reality series.
Ahh gotcha, seen some of there shows!
so of the 3 cars we have here...the race car is the only one who's aircond working properly..
re gas for the other 2 needed me thinks
add in thick as radiator and low temp thermostat...it likes it better than most cars
lol that sounds alright!
im running low temp thermostat also.. still seems when i'm in stop start traffic it can get up to where a normal thermostat will..
then back very low while driving.
bit worried about taking it out now tbh..
Car is off the road at the moment, but I reckon my oil temps would hit 105-110c in this heat in daily commuting
:O more mods?!
:O more mods?!
Never ending
Sticking a 3582 on it. Will be ready this week and in for a tune next week
Then off the road again after that to fix my front bumper then off again after that to fit an oil cooler haha
  • Like 1
Car is running ace in the heat
Because RacePace tune
I was going to get Racepace to tune it if I never got a reply from Chequered
damn tony!
going to be damn fast!
who is doing the tune?
Trent is doing the tune. Booked in for next Wednesday
Anything over 320rwkw Ill be happy with, more so to free up the engine and let it breath in the upper rpm range rather than being chocked up by the small turbo
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
