squizz try lambs or the nick stevel on sdu here the link to the ad
http://forums.skylinesdownunder.co.nz/show...&threadid=11262
he's ok I've dealt with him
meggala
Or work 48 hours a week here, get RDOs public holidays and lock down weekends, while still getting home at 4 everyday and earn 130k while not living in the desert working 12 hour days (forget what it averages out to)
No contest imo... Its a good idea if you plan to do it short term to set yourself up but most people seem to piss it up the wall on alcohol drugs and hookers..
hey brahs organizing a little meet and beach rd cruise tomorrow night, meet up at 9:00pm at the new bunnings springvale (849 prinny hwy), leave 9:30pm probably gonna go up beach rd to port melb and take photos under the bolte. Lemme know if you're keen :)
So thread has been inactive for two hours.
Go join the main chat thread in the wasteland. people talking about food and saying hello/goodbye to each other all day keeps the thread going.
Was hoping to make it to Phillip Island for track day this weekend but a) will be hot b) might have to prepare to shoot a short film c) if decide to go to beach whilst at PI, who's gonna want to come with to watch cars for a few hours? no wimminz thats for sure
inb4 everyone on wastelands earning on dat over 100K p.a
I might come
im working for a mates team at the classic car series down at pi on the 7/8/9th march, anyone else going?
You in charge of the beer fridge?
You gunna pik me up on the way through Lee?
I could. Bring bathers.
    • I was 99% sure the standard one is long enough to get there, you might just have to change the throttle orientation. If not, I remember someone having used an r31 cable instead, but that is probably harder to find than r33 by now...
    • HELP   Hey all, Is there an accelerator cable from another Nissan that can be used on the R33 GTST RB25DET with a Greddy forward facing plenum?  Thanks in advance  Rob
    • Or do we think it was installed to give 1 bar of boost max, all day, everyday?
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
