wut
http://www.my105.com/listingdetails.aspx?id=12411&latest=1
how does one put so much effort and money (and sponsorship) into such a car for so long... then sell.
...I guess cause someone else was driving/winning.
wut
they had developed as far as they thought they could take it, starting a new project to go even faster now
it will be expensive. and EPA is a scary scary organisation.
but do it anyway. it'll be awesome. NA+Ts have moar low down torque due to the higher compression. Though, budget your conversion for turbo brakes, and stuff.
I was meaning more along the lines of acquire new engine, put in new engine. Not sure if the GT-Four comes with bigger breaks like the GT-V does. Information like that is hard to find.
Pretty sure it's been done before, and there'd be certain perks in doing so.
But also consider that it's most likely cheaper and easier to sell it and buy a GTT after your four years is up.
Moreover, consider the fact you may not want a skylineand post-Ps. My mate has a 34 GTFOUR, and I'm pretty sure for a long while he was considering N.A.+T. Has the AWD as well, so.
It's actually for sale at the moment as he's just got off his p's, if you want I can find deets for you (you could ask him deets about the brakes etc at least, I forget how much he's wanting for it).
But, I digress. He's on the hunt for an STi now. Which was my point about four years being a long time ; and that things change.
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
