How do you pack a tent/sleeping bag & amenities on a motorbike? :P
inb4beargrylls
Beach just a backpack, camping meet someone down there with a car :P or with dirt bikes yeah get a trailer and dads 4wd haha
inb4beargrylls
I find that gutting a bush pig with your bare hands is a great source of food, and you can turn the pighide into a convenient backpack / water storage. Looks very fashionable on the back of a bike as well.
What is this the f**kin YouTube thread?
Anyway, three way rolling between SS ute, Evo X and old faithful.
SS gives the thumbs up after losing; this is common for Commodore/Falcon drivers to do, I've noticed...and I love it because it's just mutual admiration for another car being quicker, it's respect (to some people, that's more important). Evo on the other hand, looks dead ahead like he's thinking "why isn't my car faster? I spent 50k on this shit." Remind me again why we pole fun at the taxis when the import owners are the sore cunts?!
/stillhaventgrownup
  • Like 1
Can anyone recommend where I should be looking to get a fibreglass repair kit to fix up two front bars? Both require multi cracks etc patched over a 10+ cm area... So one of the little kits from Super cheap ain't gonna cut it...
So the cops bought an FPV GT and destroyed it "by putting e10 in it" and by destroyed I mean actually cracked the block.
What a load of shit. A tank of e10 won't do shit to a GT when driven normally...
Hypocritical pricks were clearly "hooning" for that kind of damage to be done
What the f**k do we pay taxes for again?
hmm so it's a "heavily modified" GT...wonder what EPA has to say about that.
with over 400kw....meeting every ADR natrually
used at V8 supercar and drag events...100% legal however.
and yeah lets put in the cheapest fuel we can...
prob was tuned for E85 or something and they put liberty E10 in it!!!
SS gives the thumbs up after losing; this is common for Commodore/Falcon drivers to do, I've noticed...and I love it because it's just mutual admiration for another car being quicker, it's respect (to some people, that's more important). Evo on the other hand, looks dead ahead like he's thinking "why isn't my car faster? I spent 50k on this shit." Remind me again why we pole fun at the taxis when the import owners are the sore dream boats?!
/stillhaventgrownup
Because X's aren't imports... :P
Should try it with the real cool kids, i.e. the CT9A's... say an 8... :P
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
