f**k, they are so cheap now it's not even funny, I'm hanging to buy another just waiting for an excuse
Really want the Alfa 4C in Australia :(
Not that I'd fit in it, but that would be a seriously fun machine out of the box. <900kg, 180kw turbo 1.8, 0-100 in ~4.2 seconds and they're planning a 220kw engine.
Finally an Alfa with balls that looks good and doesn't cost hundreds of thousands.
Alfa_Romeo_4C_Fluid_Metal_(front_quarter
they are coming to AU
very shortly,
circa 80K or 105ish for the launch edition with a bunch of extras and limited edition badging (fk that)
but so I have been told Alfa have stopped taking orders as they now have an expected 2 years wait list in AU.
I was waiting to jump in one to see how well I fit, but seems no point now.
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
