anyone seen a orange FG F6 with gold 5 spoke wheels (not sure of brand), lowered? thing got up on the dyno, looked pretty stock from the outside....nek minnut 581.6rwkw in 34+ degree heat.
yeah i'm edging towards them, was reading that the D2's have a crap ride if using as a daily so yeah.
D2 isn't that bad if it isn't 12.7kg at front and 11 at back.
hmm was it alright on bumpy roads?
Until I walked into the garage and noticed a pool of oil from rear left side... BTW, roads around Thommo/Epping are rough as.
Lasted 3 days under the 34 but can't complain if I paid $100 for them lol.
  • Like 1
I still need an oil cooler and fix my suspension for that :/
Maybe if the cars not such a handful
Yeah haven't had a chance to boot it yet. Little scared at the same time
Will be interesting if the hankook rs3 265's and standard diff will be able to cope
oh FFS tony, all I have heard is whinging from you about the power.
grow a pair, get in your car and drive the f**king thing,
no you wont get traction, so what? chuck it in 2nd, hit the limiter and get over your fear. it's not like you will be going fast with 0 traction,
I don't wanna hear anymore "im scared" phaggotry,,,
next post should be... "f**k that shit was fun"
oh, and get a diff
I would have said 4 minutes but I added an extra minute cause hub dyno
no need. Hub dyno is accurate unlike that racepace rough kw estimator you use
need a good wallet leather wallet, need brands and places to buy (not fossil please)
k, go.
Have a nice Jag wallet from Myers, has held up pretty well apart from side of the coin pocket tearing open but I always seem to do that :/
well my wallet of 5+ years was a Blazer (from Myer). so I think ill just go to Myer's. that was easy :| thanks fellaaas.
+1 for BC's being quite good for comfort vs handling vs price. but pulsar has ER's, but others love the other types
k, go.
paul smith - http://www.paulsmith.co.uk/au-en/shop/mens/accessories/wallets
My last was a nice Ben sherman one from Myer.
had the drivers license in a pull out with 2 card slots so if you want to travel light it was a good convertible.
have a fossil now..sucks massively no foreign currency fits.
I was given a fossil for my bday in jan... not a fan, can almost fit A4 in it...ridiculously oversized
a little lol...
I was actually going to say "drive it like you stole it...." but then I realised that you might melt the coilpacks, blow the motor and ditch it
:P
standard falcon power brah
Here you go:
https://www.facebook.com/NemLozo
see I got dem ford connections brah, he's part of one of the facebook groups I'm in - don't know him though.
Edited by UNR33L
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
