The 33 has neither the motorsport history in Australia of the 32 nor the pop culture fame of the 34 which for a lot of people just means it's not important because there's no hype and because there's no hype it mustn't be good.
The conservative styling certainly doesn't help them stand out either and that coupled with the larger body have earned them dumb boat comments, despite the fact that they're far more composed(like for like) than a 32.
It's good in a way though, it keeps prices down making the 33 exceptionally good value in any variant.
I dont know why anyone would really buy a 32r these days when you consider the 33r value
34s are what still like 40k for a 90s car dafaq?
never seen that cheap... luckiest i found 50k for 90s car -_-
I must say Artz, getting that car for free is a definite score!
attachicon.gifImageUploadedBySAU Community1392071382.088416.jpgattachicon.gifImageUploadedBySAU Community1392071406.053168.jpg
hey thanks for the pics....yeah was a good score...lets not forget the 100hours plus of elbow grease i had to put into to get it in the shape its in...
http://www.carsales.com.au/private/details/Nissan-Skyline-1986/SSE-AD-2621436/?Cr=140&sdmvc=1
This plus an auto pulsar to daily in for less than 10k. Bad idea?
Edited by bucket_boy101
lol @ all the above. including 34R's re-sale being better than every luxury car in the market.
goddamn stuffy and humid out there. can't sleep.
Want me to read you a bed time story to bed?
    • That sounds like an excellent idea. But total self-sufficiency means exactly that. You have no-one else to blame when your system faults out and you have no power for a week or two while it gets fixed. You'd have to go the whole hog and get a diesel genny and all the switchover gear, to get you through such times. And, despite the fact that over 20 years, my system has been pretty reliable**, I have seen so many inverter explosions (or less dramatic deaths), panel and roof JB fires, and so on, over that time, to know that the stuff is the same as any other bulk Chinese manufactured stuff. The failure rate is well above zero - both on the equipment and on behalf of the meth addled installation labour force. And then..... warranty and means of redress against the supplier you bought the gear from. Best I can tell is that only a handful of solar companies are still around within 5 years of starting their advertising pitch. They disappear and phoenix like crazy. So, as per 1st paragraph, I suspect the only way to is go balls deep and spend maybe 2-3 times as much as you might think, so that you have every base covered. Plus, know and understand your gear intimately, so you can diagnose problems, sort them out yourself, etc, etc. Plus, probably have to consider upgrading various parts as the years pass, to maintain compatibility with newer stuff, performance and reliability, etc, etc. Whereas, remaining attached to the grid has an ongoing cost that keeps going up even if you use bugger all power from it. But it does provide the fallback in case of the worst case with your own gear. You either pay up front or as you go, I suspect.
    • Add more solar panels to the array. Call the electricity company and tell them you're moving out... Live off grid electric wise
    • Hi Jasmine. How's the war going?
    • I'm extremely suspicious of the VPP stuff. Best I can tell, you surrender any and all control of your panels and battery to the VPP, because there's no way that anyone could write a sufficiently useful set of "rules" as to how much you would be willing to let out of your export meter at any given time. If one of your main interests is to have enough in your battery every evening to get you through the night without having to import, you could easily find yourself with nothing in your battery at the end of the day, or part way through the night, and then be paying import pricing instead of paying nothing. I cannot see how this cannot come to pass.
    • majority aftermarket is an10 yes, but majority of OEM is An12 r35 OEM cooler lines at close to an 12, the hard line that car uses is almost 20mm  Porsche OEM is also AN12   i figure, if our power levels are close to 1000hp, then AN12 should be a must if many OEM standard power vehicles use AN12
