I don't really care I flog it anywhere now, dat non import lyf
fkn this.
I gave up caring when i got my SECOND speeding ticket for less than 5km over.
if they are going to book me anyway, I might as well do what the fuck i want
Not that I doubt Damien's abilities, but unless he can add a 4th dimension to the universe, I can't see the reflection being any deeper/better than a pure mirror :P
Artz and Birdz detailing ftw
looool
Don't you have an r33? You'll need side feeds if you aren't doing rail conversion
This. The ID website said the ID2000's are for RB25/26. huh?
I've heard 1000cc + injectors can cause idle issues using a PowerFC on PULP? Of course if going e85 I'll go ID's..
I've got ID1000's and it did have some idle ups and downs occasionally with PowerFC, but that was with trents tuning (wasnt harmful or anything). Been elsewhere and havent had the issue.
Id1000 brah checkin in
Go big injectors and do it once
You'll eventually upgrade in the future and want headroom if you ever go e85
Dino fuel lover to e85 guru in 1 tune session. My work here is done. :P
weird. he knows exactly what causes that and usually corrects it... was he in a rush for that tune?
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
