Between that and cams it would almost shut off at 800rpm
Cams can affect vacuum to the extent it is difficult to idle, good chance that was your tractor's only issue, other than the driver... :P
My 1000's idle perfectly.
It was probably more so cams but only started after injectors.. Either that or Cihan lol
Bosch 1000s checking in.
Although they're still sitting on my desk, and not installed, XD.
I was going to get ID1000's as well though. Although they're really the same, I think, just flow tested or whatever etc / up to you whether to believe marketing.
Dino fuel lover to e85 guru in 1 tune session. My work here is done. :P
Lol well I was always going to go to e85 just not so soon.
A bit unexpected when Trent says ok lets do an e85 tune whilst where here lol
Going to Daylesford next weekend. Thinking of putting an e85 jerry can in the boot just in case :/
got an email from commbank. theyre phasing out signed transactions, all cards must have a PIN. a win for security yay.
in other news:
http://theage.drive.com.au/motor-news/classic-corvettes-swallowed-by-sinkhole-20140213-32j5b.html
Yeah mine has hunted a bit as long as I've had the car... ever since before the PFC went in (had a Mines ECU beforehand)... It just bounces harder with the PFC I think because it's more aggressive at trying to recover from a low rpm...
With the A/C on, sitting in traffic, it'll sometimes start bouncing 600-1200 rpm with a 2 second cycle... Can see the vacuum levels are fine, but obviously that looks like its bouncing too with the change in rpm...
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
