I'll line up, and charge Alex a premium before race wars
edit: $150 a hour? sure
nah but srs yeah 150 seems fair for whoever needs money, similar to dat dere flaggy money @ sandown
Edited by UNR33L
So carrying on from a couple pages back, does ID make 1000cc side feed or would I need a GT-T or GT-R rail? And also will my R33 GT-R fuel pump support e85 and flow enough for ~270rwkw? What else do i need? Fuel filter obviously, will the lines be okay? e85 n00b here ;)
You will need to change to a top feed rail. A Walbro 400 or similar would probably be a worthwhile upgrade. Lines will be fine but really you're supposed to replace all rubber fuel lines every 5 years..
nah man i collect them its for my personal collection.
must acquire.
I know a guy with literally hundreds of pairs, is mad into all the new releases etc. Can put you onto him if you can't get a slave to line up for you
And I can't edit on the app
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
