R1R 205/45/16. Yup, 4x100 16x7+33
7" bit skinny for your power innit? :P
R1R is so HNNNNNG in the wet. So so good. Picks up so much shit and flings it in the guard though
Got it through streeter, not very often you see this pop up. Haha, its forged too, around 6kg each.
<3 R1R wet times
Wish they were a bit better in the dry though.
this micra is going to be the little car that can, if you go through with all that you're planning. decked out from top to bottom.
inb4 Thule roof racks with single speed ontop and stance.
Do you have old rims/tyres your going to get rid of?
i hate stance.
im all for filling arches with wheel, but if it aint practical, it aint going near it.
roof rack will help to transport gear to track tho!
spent many hours chatting to scotty last night about the way to go, and he has dragged me kicking and screaming from the ghetto cooler piping i wanted..... ive still got my heart set on a jdm exhaust system or at least rear muffler tho...
Yes, but they're all sold. And most likely cost a lot more than you're looking to spend. Haha
6kg? fuuuaark. 7" is all im running at the moment. anything bigger is scrub-city.
My te37 15x7+35 was around 4kg.. :P
<3 R1R wet times
When they're hot they perform awesome. RSR had better grip than these R1R at cold/warm daily temperatures though (dry). But R1R feels crazy when hot.
Can't wait to hit winton now.
Touche'
I need to get new tyres but figured some of the rims on "JDM rims for sale" you can get a set of rims and semi decent tyres for not much more
See you soon at winton brah
You're spending money on a micra? Can I ask why?
I saw a little toyota starlet the other day at Trent's pushing 190kw, he was going in for an ethanol tune.
There is no way you would expect to get thrashed by a micro car, with a baby on board sticker on the window. I'm all for it. :)
really? :unsure:
my 16x7 +33 is like 8kg without tyres and 14-16kg with.
Pretty sure it was 4kg without tyre.
Touche'
Haha yep. 2nd hand usually better.
When's sau winton day? Going tampered on 10th, I wanna beat my 53, especially when the 53 was my last lap of the day, and the car still had more in it. Gonna have even more in it now due to tyres.
Dezz doesn't like anything.
If dezz was a word in the dictionary, it's meaning would be; "He who hates the world and all it possesses"
maybe Hamish and Dezz should partner up and fight crime or something
    • When I said "wiring diagram", I meant the car's wiring diagram. You need to understand how and when 12V appears on certain wires/terminals, when 0V is allowed to appear on certain wires/terminals (which is the difference between supply side switching, and earth side switching), for the way that the car is supposed to work without the immobiliser. Then you start looking for those voltages in the appropriate places at the appropriate times (ie, relay terminals, ECU terminals, fuel pump terminals, at different ignition switch positions, and at times such as "immediately after switching to ON" and "say, 5-10s after switching to ON". You will find that you are not getting what you need when and where you need it, and because you understand what you need and when, from working through the wiring diagram, you can then likely work out why you're not getting it. And that will lead you to the mess that has been made of the associated wires around the immobiliser. But seriously, there is no way that we will be able to find or lead you to the fault from here. You will have to do it at the car, because it will be something f**ked up, and there are a near infinite number of ways for it to be f**ked up. The wiring diagram will give you wire colours and pin numbers and so you can do continuity testing and voltage/time probing and start to work out what is right and what is wrong. I can only close my eyes and imagine a rat's nest of wiring under the dash. You can actually see and touch it.
    • So I found this: https://www.efihardware.com/temperature-sensor-voltage-calculator I didn't know what the pullup resistor is. So I thought if I used my table of known values I could estimate it by putting a value into the pullup resistor, and this should line up with the voltages I had measured. Eventually I got this table out of it by using 210ohms as the pullup resistor. 180C 0.232V - Predicted 175C 0.254V - Predicted 170C 0.278V - Predicted 165C 0.305V - Predicted 160C 0.336V - Predicted 155C 0.369V - Predicted 150C 0.407V - Predicted 145C 0.448V - Predicted 140C 0.494V - Predicted 135C 0.545V - Predicted 130C 0.603V - Predicted 125C 0.668V - Predicted 120C 0.740V - Predicted 115C 0.817V - Predicted 110C 0.914V - Predicted 105C 1.023V - Predicted 100C 1.15V 90C 1.42V - Predicted 85C 1.59V 80C 1.74V 75C 1.94V 70C 2.10V 65C 2.33V 60C 2.56V 58C 2.68V 57C 2.70V 56C 2.74V 55C 2.78V 54C 2.80V 50C 2.98V 49C 3.06V 47C 3.18V 45C 3.23V 43C 3.36V 40C 3.51V 37C 3.67V 35C 3.75V 30C 4.00V As before, the formula in HPTuners is here: https://www.hptuners.com/documentation/files/VCM-Scanner/Content/vcm_scanner/defining_a_transform.htm?Highlight=defining a transform Specifically: In my case I used 50C and 150C, given the sensor is supposedly for that. Input 1 = 2.98V Output 1 = 50C Input 2 = 0.407V Output 2 = 150C (0.407-2.98) / (150-50) -2.573/100 = -0.02573 2.98/-0.02573 + 47.045 = 50 So the corresponding formula should be: (Input / -0.02573) + 47.045 = Output.   If someone can confirm my math it'd be great. Supposedly you can pick any two pairs of the data to make this formula.
    • Well this shows me the fuel pump relay is inside the base of the drivers A Pillar, and goes into the main power wire, and it connects to the ignition. The alarm is.... in the base of the drivers A Pillar. The issue is that I'm not getting 12v to the pump at ignition which tells me that relay isn't being triggered. AVS told me the immobiliser should be open until the ignition is active. So once ignition is active, the immobiliser relay should be telling that fuel pump relay to close which completes the circuit. But I'm not getting voltage at the relay in the rear triggered by the ECU, which leaves me back at the same assumption that that relay was never connected into the immobiliser. This is what I'm trying to verify, that my assumption is the most likely scenario and I'll go back to the alarm tech yet again that he needs to fix his work.      Here is the alarms wiring diagram, so my assumption is IM3A, IM3B, or both, aren't connected or improper. But this is all sealed up, with black wiring, and loomed
    • Ceste, jak se mas Marek...sorry I only have english keyboard. Are you a fan of Poland's greatest band ever?
